ORIGINAL: KitBuilder
Hot enough to cause blisters??? Is the setup correct? Even with airflow I think it may be masking a configuraiton problem.
You have another problem besides air flow then. Hot warm is about it, blisters is telling you there is a big problem. Like builder said, it's something in your set up. If you go over to Wattflyer you may get a lot more insight into your problem. Go into the beginners forum and post what motor, ESC and battery you have and I know they can help you out.
