Question on BME 50
New to gas. Does everyone use a velocity stack on the carb?
Is it advisable to solder a brass tube on the hole of the metal diaphram cover and route the brass tube outside the cowl to avoid irregular air pressure that may be inside the cowl?
Any comments and suggestions would be appreciated. Thanks.
