RCU Forums - View Single Post - Uneven aileron throw... How to?
Old 08-19-2010 | 04:11 PM
KitBuilder's Avatar
KitBuilder
Default RE: Uneven aileron throw... How to?
I learned with the grey more nuetral (vertical) ... then this will translate into lessdifferential since it's just relying on offset at the servo end. Offset at both ends provides more differential... or the capability to increase differential if needed. You cannot adjust installed torque rods but you can adjust servo connection so better to have the angle in the torque rod as well during building.
</p>
