RE: I need some advises and help from nitro pilots
Also since you psooibly do not have much engine experience get the local club engine guru to make sure the LA is giving it's little all and you have the right prop on.
BTW the guru is probably the one whose engines always start instantly, no problems in the air and he lands with them running NOT the guy who spends all his time running his engines on the ground changing props and playing with the needle settings.
