RCU Forums - View Single Post - Senior Telemaster~where?
Old 08-20-2010 | 11:24 PM
OzMo's Avatar
OzMo
Default RE: Senior Telemaster~where?
BUILD THE TELEMASTER KIT!
Hi, really if you want a Telemaster DO IT! Heaven knows you can get all the help you ever wanted here but I doubt you would need it. They are not hard to build or cover. And with a kit you can make any minor changes you want easily. I have a Telemaster 2000 I use as a glider tug and I have a sig LT 40. On my LT 40 I used only half the dihedral. It handles wind just fine, flys inverted well. With a Sr. Tele kit you could do the same.
Building tip: Before covering spray polyurathane into the gas tank area and the floor of the fuse as far back as you can and around the engine area. Even if you do get a leak ...no problems. I even hit the opening clear back at the aft end to eliminate oil soaking from exhaust.
