RE: HK Small Bolt Hydro same as HOTR
Voltage of battery was 3,86 V readout after the run. Pack was fully loaded, everytime with a balancer.
The 1550 mAh lipopack (20C) was ok, I normally storage it on 3,8 V per cel. Today I have discharged it after fully loaded, and after 4 minutes and 15 A full discharging all 3 cells where 3,55 V. it tooks about 8 minutes for fully discharge (1436 mAh total readout). Temps where about 100 F/45 C. So the pack seems to be ok...
I tried to get into to program settings of the esc that comes with this Bolt, tried the manual of nickster46 and even with a program card but it seems not programmable... Only thing you hear -in different stick positions of the transmitter- is the 2 short 1 long sound that may should give an automatic setting of your stickposition as mentioned in the manual of nickster46.
Next time I try a different pack and, if it slows speed again after 3 minutes, with a different esc it should give some answers... We will keep trying!
Greetings, BJ
