RE: briggs 4 stroke prop?
It was glued on when I got the hull, looks like an extra or yak or something, it works well though. Next time I'm at my friends house I'll grab the camera and get some video, it should be more impressive with the new prop, I actually drove it like a foot on grass last night as before it would only move about 1/4" with the big prop(it has a fin on the bottom, it's not just flat, if it was flat it would have just gone)
I got the starter idea from someone on youtube a couple years ago but they had a much more complex setup and used a standard starter cone or a socket on the prop bolt or something, I liked my idea better... now all I need is to find a cheap hand truck to haul this thing around... this dang 4 stroke engine starts on the first pull, prime, choke, pull then turn the choke off and you're going. I figured if they don't run right without an air filter since it doesn't have adjustment needles, just leave the filter on... I tweaked the regulator arm up a little to help too. Apparently the spark plug that came in it is a resistor plug as I have no radio noise, I could get used to this computer radio thing in cars/boats too, makes setup simple.
