ORIGINAL: MThemadhatter
Hi all
I have had a search through the manual and this thread but can't find the answer to this.
I am setting up a model with dual flap and aileron servos, the channel set up screen only says ''aileron, aileron1''. Which is the left aileron and which is the right ? What is the convention with the Aurora 9 ?
Just pick 2 channels and name them aile and ail2, or flap and flp2. There is no real convention, just do what you want. Use whatever channel for whatever you want.
I usually set channels up to make the wiring neater, particularly if I use a power expander, and to make it logical. For example I use the rear channel on either side for elevators, that makes it easier to remember what goes where.
TF
