RCU Forums - View Single Post - Semi flexible elevator control rods ?
Old 08-25-2010 | 08:09 PM
Edwin
Default RE: Semi flexible elevator control rods ?
Semi flexible? I use 4-40 steel rod in tube. You can get both at Tower. The 4-40 rods are threaded on one end and come in vairous lengths up to 48". I generally solder a 4-40 metal clevis on the servo end and use the threaded end at the control surface.
Yeah, I gave up on golden rod and nyrods years ago. They only get used on throttle, choke, and ignition switches.
Edwin
