RCU Forums - View Single Post - New Hitec Aurora 9-Channel 2.4Ghz Radio System
Old 08-25-2010 | 11:04 PM
  #2920
rctom's Avatar
rctom
Default RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
ORIGINAL: JIMF14D
Well I thought the purpose of the little canned top level menu that leads you through # number of engines, wings, tails, air brake, fuel adjust etc was designed to speed up the basic model set up so you don't have to stop and assign channels and servos for basic model set up?
What am I missing?
Maybe nothing. The first thing I do is set up my channel assignments and I have never used the setup "wizard". I like knowing exactly what is going on, it takes less time to do it myself than it does to use the wizard and then try to figure out what it did and then correct it to the way I want it.
But that's just me. So I don't know what the default setup is because I never use it.
Sorry to appear ignorant. Really, I feel silly that I don't know the answer to probably the most basic question because I always just skip over that part.
TF
