ORIGINAL: spaceworm
What is the PH of castor oil?
If you put your finger over the plug hole, why even take the plug out? Is it to put in fresh fuel through the plug hole? If you are doing that, why not just load it up with ATF or air tool oil? Why not just run FAI fuel, with no nitro since nitro in the big offender, Right? And, what is the PH of FAI fuel? What 2 stroke oil do you recommend for gas engines? (I had to add that last just to stir up the hornets nest some more). Thanks.
Regards,
Richard
There is no information on its PH level for Castor Oil, sorry: ref
http://www.jtbaker.com/msds/englishhtml/C1500.htm
So then we wouldn't have any PH info for FAI fuel either as it is methanol and castor oil.
Yes FAI types of fuel is the way to go, no nitromethane in it. But here in the USA most modellers are hooked on using some nitromethane in their glow fuels. Usually many engines in the USA market are designed to use nitromethane in the glow fuel too. These engines typically do not run all that well off of no-nitro glow fuels. You would have to modify them to work better.
As for gasoline engines, use whatever 2 stroke oil you like a lot more to choose from. Since gasoline engines don't normally run nitromethane, you won't have any problems.
But years ago the special synthetic 2 cycle oils were known to be hydroscopic and tend to absorb moisture. A lot of guys found out about that the hard way, after parking their 2 cycle motorcycles for the winter. Then when they went to use them in the springtime, the bearings were all rusted out and bad. So it goes to show that synthetic oils do not really protect a engine from corrosion on the inside. So that led to the oil companies using blends with synthetic and mineral oils as one solution.
Now as for those gasoline engines that have been converted to run nitromethane and methanol, you have the same corrosion issues from nitromethane. But usually these engines are used in racing, so they get taken care of really well. If it is a 4 cycle gasoline engine, you need fire protection systems in the sump to prevent sump fires or put them out. That can get exciting if it happens to you and you are in the drag car sitting behind the engine when it occurs.
