RE: T606 Charger
Why would you worry about your car battery? Once you start it up again it will charge back up from the little that you would use in charging your LiPo'sbattery. Also charging by computer is a very slow method Iwould think,plus if you were to do the computer charge out in the field it would drain you computer's battery. Imay be wrong in my thought process,Iam sure someone will have a more definite answer,
