ORIGINAL: zac137
ORIGINAL: exeter_acres
I thought the 7C 2.4 radio had a built in ailevator mix?
if it does, use that.
It does. I can't really figure that one out. The evelvators keep going opposite directions.
thanks for the info
The dual elevator function is enabled if they both move at the same time. If going in opposite direction, you will still need to reverse one of the servos on the TX.
