RCU Forums - View Single Post - Need some help. Tornado s30
Old 08-27-2010 | 08:47 AM
cswtornado's Avatar
cswtornado
Default RE: Need some help. Tornado s30
I have the Tornado BB (which is a powered down older version of the s30) and I love it. There are a few things that you might as well buy in bulk along with the car thogh. I will list those later.
how do you upgrade the sh .18 to a sh .28?
...You can't. The .18 is plenty big enough, and the .28 is HUMOUNGUOS. No chance of it fitting
Second, how do you tune in the motors?
Thats a bit harder to answer. There is no exact formula for tuning, but you want the car to run between 200 and 290 degrees farenheight (to avoid damage) As long as the motor stays within those tolerances, and is not too lean, you can tune for performance as much as you'd like. If you had no idea about what i just said watch this video (actually, watch it anyway)
<span class="Apple-style-span" style="font-family: Verdana, Arial; font-size: 13px; -webkit-border-horizontal-spacing: 1px; -webkit-border-vertical-spacing: 1px; ">What other than extra glow plugs, nitro, and a starter kit will I need?</span>
Extra dogbones(3 packs), wheel hubs(1 pack), Fail Safe (just one. It seems expensive but it pays for itself later on), 47 tooth gear (get 5 or 6), 2nd gear spur gear (just one),Temp Sensor (just one)
You cannot use the Volcano's wheels without a decrease in performance, because that will dramatically change the gear ratio, and the stock tires work well on gravel, dirt, and pavement.
Watch this video on break in tips.
Whew....All done!<br type="_moz" />
