RCU Forums - View Single Post - pinch test
Thread: pinch test
Old 08-28-2010 | 12:04 PM
Rodney
Default RE: pinch test
In all the pinch tests I've ever seen or done, it deals with the high speed adjustment only. Turn the needle valve to get what you think is the maximum safe RPM. Now pinch off the line to the needle valve. If the engine dies quickly, it is set to lean. If it slightly speeds up then dies, it is just right. The pinch test has nothing to do with the low speed needle valve adjustment.
