Quick Question
Which way does the throttle rotate on the Redline 53HX engine?
If you are looking at the engine from the front with the glow plug pointed up and the throttle arm is on the left side, which way does the throttle rotate for closed?
If you are looking at the heli from the left, the glow plug is pointed towards the nose of the heli and the crankshaft is pointing straight up with the throttle arm pointing towards the ground and rotates towards the nose of the aircraft and towards the tail.
the piece the throttle is connected to slides in and out of the carb a little if that helps.
Any help would be greatly appreciated. Jeff
__________________
