ORIGINAL: zero244
GizmoMax: I think what they are trying to say..........is if your not going to use the SPC port you have to put the jumper back in that came with the rx.
You have to either use the SPC by applying a power source or not use it and make sure the jumper is connected.
If the rx wont boot up with the jumper connected then you may have a problem.
AW MAN, Awesome, that is it, WOW, i somehow missed that until you mentioned it zero244!!!!! GREAT Job...
Now I did look back and sure enough RCTom mentioned it, but for some reason, the reverse wording by you hit the old noggin, duh on my part.
Then all the while, AT did a GREAT job on superb Tech support as always!!!
Sure enough, I just tried it, and it works perfect with the jumper plug in the spc port, so NOW i finally feel good that the 9-channel is working, I forgot I removed it a few months ago when I started this project, duh, my fault....
So now that I know everything checks out and YES folks, I will remove the jumper and power the SPC via the 7th server smartfly port!!!
so I hope to maiden this sometime this week!!!
thanks to all again!!!
Cheers !!!
