Michel - I don't use flaps, so this is purely an absolute GUESS....but it's an attempt, anyway.
I think you need a mix of THRO >>FLAP, probably a multi-point, and use the OST (OFFSET) to adjust the "deploy" part of the throttle movement, such that at that point, you have FULLmix (FLAPSgo full down, or what ever percent you want), then you can also set the flaps to track with throttle, if you want that.
As I said, I don't use FLAPS, but I have a smoke channel similarly setup, controlled by both a switch and a multi-point mix of THRO>>SMOKE, with an OFFSET, and it's doing what I want. I did a LOTof playing with it and watching the effects of things in the MONITORfunction until I had it close enough to actually setup. Ended up that what I'd set visually using the MONITORFunction was very close.
ORIGINAL: michel gravelle
Hi
Thats a great site you put up AT , and it was fun . the best I was able to do was .254 , ..................
works for me . Must be age
Well I have a new question if someone would be kind to answer .
I have my flaps working . They are set on a three position switch . I used the end points to set '' UP '' and '' FULL '' flap . I used '' SUB '' to set my half flaps .
I have read the manual , but the wording doesn,t seem to match the way '' I '' understand it to read .
Here are my questions .
1 ) is this the right way to set-up flaps ?
2 ) I would like to have my flaps work at a certain percent of throttle ( this is where I get stuck ) This would mean that if I go lower than half flap ( for example ) , the flaps will deploy .
Any help would be appreciated .
Michel
Hi
Any chance someone can give me a hand with this question .
Thanks for looking
Michel
Hi
Any chance that someone could have a look at this question
Could you Hitec guys have a look at this PPPPPPPLLLLLEEEEEAAASSSSEEEE
Michel
