RCU Forums - View Single Post - New Hitec Aurora 9-Channel 2.4Ghz Radio System
Old 08-29-2010 | 10:20 PM
  #2939
A.T.
Default RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
ORIGINAL: michel gravelle
1 ) is this the right way to set-up flaps ?
2 ) I would like to have my flaps work at a certain percent of throttle ( this is where I get stuck ) This would mean that if I go lower than half flap ( for example ) , the flaps will deploy .
Hi Any chance that someone could have a look at this question
Could you Hitec guys have a look at this PPPPPPPLLLLLEEEEEAAASSSSEEEE
Michel [/quote]
<span style="font-size: smaller">Babysitting (literally &amp; did not bring Aurora as it can not change nappies.)......</span>
Required mixwould be similar to setting up low thottle activated on/off switch using P-Mix etc.
http://www.rcuniverse.com/forum/fb.asp?m=9752681 or a variation on
Aurora A9 - Retracts and Flaps Set up with Various Flight Conditions - posts #2052 &amp; #2054.
Test scenarios using the monitor function.
will check further tomorrow.
regards
Alan T.
