RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
Hi Michel,
Yes, you can setup the flaps in such a way that when you are lower than half throtle, the flaps will deploy to set levels. Alternatively, you can set the flaps to any of the side sliders so at full up, the flaps are level (0), at mid click tone - mid way and full down - fully deplyoed.
I have setup my Cessna Gasser 26CC such way, when i am lower than half, the flaps deploy the mid level and when i am down to idle, the AIRBRAKES will function making both the ailerons at full high, flaps at full low and elevaterlittle DOWN.
You need to mix the channels to logic the function.
Throtle ch mix to FLAPS
Flaps to Ailerons
Throtle to Elev. mix
IMPNOTE:Airbrake function is a bit tricky and need to be properly setup. If your brakesturnsONfirst before you actuallytouch down, you will crash !!!! - TRY FEW LOW PASS LANDING CHECKS WITH AIRBRAKES ON AND OFF, SEE THAT THE PLANE REMAINS LEVEL WITH AIRBRAKES, GENERALLY GOES UP, THEN ADD A LITTLE ELEV. TO LEVEL.
I did this with my Futaba 9C, but with lots of logic and trials breaking my head, but with Hitec A9, you have user friendly icons to click.
Try it and let me know.
Hemal
