RCU Forums - View Single Post - Skymaster L39 build
Old 08-29-2010 | 11:53 PM
  #344
JackD's Avatar
JackD
Default RE: Skymaster L39 build
ORIGINAL: VF84sluggo
Thanks for the info Jack. You echoed exactly my concerns about the EZ Air, so I'll abandon that idea. Can you give me the make/model of your gyro? I agree about the takeoff roll being a high-risk phase. If a gyro will help keep it tracking straigt, then I'm all for it. Any pics of your wheel wells showing the routing of air lines and servo wires will be most appreciated!
There's definitely light at the end of the tunnel now on my build. Initially I'd built it exactly per the BVM Supplemental Instructions, and it was incredibly tail heavy. BVM has the ECU, air multivalve, fuel pump, filter, UAT, etc all in the engine bay. Man, that was a lot of weight aft. I got demotivated knowing I was going to have to basically start over and move everything except for the turbine up front under the canopy and windshield. Then, it seemed like it was one step forward, two steps back. I got demotivated. But, I got back into it a few weeks ago and now I'm close to the finish line...got my ''building momentum'' back!
Here are some pictures.. hope they help
#1 Air lines detail
#2 Servo leads detail
#3 Wheel closed, you can see there is plenty of space
#4 Turbine install. Nothing in the turbine area, just the turbine itself
#5 Install under the cockpit. Solenoids and regulators are underneath the board
#6 Install under the front cockpit: breaks tank, Fuel pump and UAT (balanced it with the UAT full). Gear and door air tanks are on top of fuel tanks (different from Skymasters instructions
#7 Canopy frame tabs. one on each side
#8 Ugliest shop ever.... but hey... at least I don't need to build in my living room!!!
Jack
ID:	1492428   Click image for larger version
ID:	1492429   Click image for larger version
ID:	1492430   Click image for larger version
ID:	1492431   Click image for larger version
ID:	1492432   Click image for larger version
ID:	1492433   Click image for larger version
ID:	1492434   Click image for larger version
