RCU Forums - View Single Post - Sebart Wind S Pro
Old 08-30-2010 | 07:39 PM
  #180
tewalker01
Default RE: Sebart Wind S Pro
Arch,
The same for me. I set the plane in a foam stand with the wing at .5 degrees and then set thestab at 0 degrees. It seems to be a good starting point.
I'm currently trying to find a cg that I like. Where are you running your cg (As in mm from the leading edge)?The instructions say 190mm to 210mm.
Terry
