RCU Forums - View Single Post - la 40 too small
Old 08-30-2010 | 08:51 PM
scooterinvegas's Avatar
scooterinvegas
Default RE: la 40 too small
I have 2 Superstars, and 10" is the max you can run unless you extend the front gear and ran a little bigger tire. If you can get the front up a little bit, I would try a APC 11x4 or 11x5.
The LA 40 is the best running, easiest to tune .25 sized engine I ever owned.
