RCU Forums - View Single Post - Moki Engines Thread
Old 08-31-2010 | 04:34 PM
captinjohn
Default RE: Moki Engines Thread
</p>
<actinic:carterror prodref="249"></actinic:carterror>We have just received a very limited number of the original Moki 1.80 petrol engines made by the genuine Hungarian factory. Fans of the Moki engines will already know that this engine is Very easy to start and operate, it throttles like a glow engine, has very low vibration and is a nice compact size (low weight plus very slim).
We can supply a variety of exhausts to suit, the BCM mufflers for the 1.80 glow will fit and we can make our own J'EN inverted muffler where a nice slim profile is required.
Our own tests of this engine a few years ago resulted in an impressive 20lbs of thrust! Very good for 1200g weight plus ignition.
As with the entire Moki range, we have full stock of spare parts.
Each engine is bench tested before despatch so occasionally there may be a 24 hours delay from order to despatch</p><hr />The above was a cut &amp; paste from the Just Engines website. The Gas version appears to have needle bearings on the connecting rod! The Walbro type carb is a big plus too. If it works out...I will add more photos &amp; data. With 20 Pounds ofthrust...it should pullgood! Capt,n<hr />
