ORIGINAL: blw
ORIGINAL: lablover
Good God man
Tons of info here for a newbie....Think my eyes are bleeding now. Now I'm almost afraid to break in my new 2 stroke OS 55AX
I can tell I have tons to learn,....Pinch???? Not sure what that even is yet
Time for more EYE BLEEDING
Yeah, I figured that would have happened a good ways back.
What we call pinch is where your OS engine is different than your car. Your car has cylinders with straight walls. It has the same diameter at the top and bottom. The compression comes from the rings as they squeeze against the cylinders. Your engine doesn't have rings, so it has to make compression some other way. This is done by making the cylinder slightly tighter at the top. The piston hits this tighter area as it comes up and this creates compression.
The compression is necessary to squeeze the fuel/air mixture for being burned.
Compression comes from the piston moving to create less volume in the cylinder/combustion chamber. The rings and oil film create the seal between the piston and cylinder. The taper is there to control the dimensional characteristic of the cylinder so that the cylinder is straight during operating conditions (temperature) A ringless aluminum piston does NOT rely on the taper to seal. It is the film strength that results in the seal. This demands great accuracy in control of the piston to cylinder clearance. And it is this demand for accuracy that make the breaking of ringless systems so critical (no rings to take up the slop).
In an ABC/ABN system the tapers and interference (pinch) control (address) different concerns with regard to drag and sealing ability at operation temperatures. Now most of this is controlled at the point of manufacture so one has little control over these. But one can control the break in (stress relief {thermal or machine}, work hardening) and as such should be done on the bench to avoid a lean run during this critical phase.
Now many high performance engines were available with different size pistons to take into account the various fuels and power setting one might expect the engine to perform at. No one fit is suitable for all applications.
Konrad
FYI: I set up all my full sized air cooled car engines (2.0L to 3,3L) with cylinder taper and these also had rings. Again this was to control the difference in size at the top of the cylinder as a result of heat.
