RCU Forums - View Single Post - Firewall to Carb Clearance?
Old 09-01-2010 | 10:38 AM
captinjohn
Default RE: Firewall to Carb Clearance?
Itseems like 9/16 would be ok, but if you wantmore clearance you could cut a hole inthe firewall the dia of a small plastic round container and epoxy thatin the hole. If you wanted too...you could add a drain tube out of the round container. Capt,n.
