ORIGINAL: gr8flyer55
If you can't see anything wrong or missing Charlie, then I sent you the correct edited layout.
So far, I think the small .1 uf cap across the hall leads has solved my misfires at low speed. If we could only change the firing to after the magnet passes, it would be great. Alot must be changed for my hall mounts to accomodate the early firing.
I've been doing a work-around on that and it seems to be ok. Maybe the pickup point can take care of that? Not sure yet.
John
Not sure why you want to change to after magnet passes but just a thought, you could put a simple inverter on the input from the hall effect switch.
Jeff
