RE: BLADE TRACKING
Did you replace those 2 O ring on the Heads (some head have 4), Dampers they call it. That might be your problem if your damper are bad due to crash, it will give you hard time to track those blades. I do also have the heli max Ace 400 before and I encounter those, I thoght its the bearing but found that those damper are damage, or crack.
