RCU Forums - View Single Post - Wing flutter
Thread: Wing flutter
Old 09-02-2010 | 06:21 PM
BMatthews's Avatar
BMatthews
Default RE: Wing flutter
Only if it wasn't a control horn or pushrod that pulled out or apart. If you're going to explore the higher speed side of the flight envelope you may also want to look at modifying the ailerons to add strut like mass balances at mid span and maybe mass horn balances at the tips to move the balance point of the ailerons closer to the hinge line.
