ORIGINAL: huck1199
Switch the rudder servo to a different channel and see if it behaves the same way. If so, you know it is a bad servo.
Thanks... I switched rudder/elevator and the same servo still made the noise. BUT, I can trim it all the way down and it will stop??? Just like the Throttle??
Now I don't know what to do because this is a new plane and I don't need to be buying new parts to fix a new plane....But I want to fly it!!
It's a 50A brushless ESC and the Servo is a sub-micro.
Are the sub-micro's allthe same physical size orshould I take one with meto a hobby shop to match?
