RCU Forums - View Single Post - Sebart Wind S Pro
Old 09-03-2010 | 01:15 AM
  #190
underwoodsteve
Default RE: Sebart Wind S Pro
hi matt,
jig the model so the wing is giving you +0.5 deg , on the wing and fix the model steady at this point , now adjust your tail in to 0 deg on both sides and lock it off , ref to the thrust line i have et mine to the nose of the model , and will adjust the thrust lines if required,hope this helps.
rgds
steve
