RCU Forums - View Single Post - Fuel not getting through
Old 07-28-2003 | 01:22 AM
pistole
Default Fuel not getting through
You are probably , overheating that engine ...... the fuel is vaporising as it enters the carb .......... put both your HS and LS needles at 3 1/2 turns out from 0. The LS needle can only be set with the throttle arm at 0.
Bye.
