Thank´s my friend
At the moment I still deal with details and still long not everybody are ready. Ordinarily I go forward Gradually and make a side after the others, here, nevertheless, this runs anyhow all over, as well as I just feel like.
Macroadmission
Duplicate MG in the bug
For the case I stuck together 2x2mm Poly records and worked on this with a drill (Proxxon) The MG's exist of 2 and 3 mm of brass pipes
Driver's hatches and small hatches
Camouflage lamp, lamp and signal horn. I provided the protective hanger from 0.5 mm of brass metal (soldered)
The curvature in the Kasematte on top is also new
Selfmade tank lids (knows lacquered to see like the surface will look) and stiffening metal (bronze metal)
the rear lamp is a modified Tamiya Sherman component. I have twisted the article about 90 degrees.
Airing grid
Furthermore I have many screws and rivets verbasteln again are able
However, the rear is not formed yet ready, there are still no still cultivation parts
