don't worry!
Don't worry! I've had five of them! Some I built some by others and as long as the 1/4 is done at the leading edge, you will be fine. If you really are worried just take back off the speed brake abs plastic and reglue correctly to where the trailing edge lines up. good luck on your maiden flight! KG
