RCU Forums - View Single Post - Advice on getting an old engine running again?
Old 09-04-2010 | 06:02 AM
Mr Cox's Avatar
Mr Cox
Default RE: Advice on getting an old engine running again?
I think it is better to take the backplate off when flushing an engine. That way you get the stuff out it without having to turn the engine over. It will also give you a view of the rear bearing (if the crank allows you). The rear gasket will often need replacement then but new ones are easily made from gasket material.
