RE: SE.5a 1/5 Scale build
Thanks for your kind words Pat.
Even that it has flown and it flies very gently I am still interested on bringing a bit down the upper wing. The procedure is simple as I see, I will glue some hard wood blocks in the lower side of the upper wing part (where cabane struts attaches) once that I have cut the cabane struts at the desired lenght. I will use the robbart incidence calculator, which I acquired for that purpose (even that I have also used now for many other planes and for two helicopters).
Cheers Pat.
Alfred.
