RCU Forums - View Single Post - Diluting Pre-mixed fuel....
Old 09-04-2010 | 05:06 PM
briangp
Default RE: Diluting Pre-mixed fuel....
Just a follow up for everyones information....
Finally ran the 1.08 today with the stock 5% SIG fuel (20% oil)... took a little bit to start it, it was so stiff from sitting around, we blew it out by pulling the plug and running it with the starter.... UGLY brown **** comign out.... lol Put the plug back in and it fired right up! Adjusted the high speed needle to a little under 2 turns out and its running extremely smooth, idles super low, and transitions to high throttle like a chain saw! I broke it in on a pole with a 15x8 prop on it... I don't think it even knows theres a prop there! I'm running no shims, and 5% and purring like a kitten! Its not getting hot at all, we ran about 5 ounces of fuel through it with a couple seconds of WOT, and about 10 minutes of idling. Its not loading up at an idle... I couldn't be happier with it right now....<br type="_moz" />
