RE: Offset flap hinge position
Just make sure that the hinge points line up perfectly or else they will work against each other as the flap deploys. Also, you will need a very high torque servo since this setup does not have allot of mechanical advantage. In fact, there is allot of mechanical "disadvantage" with this setup.
Jim
