RCU Forums - View Single Post - Building the Flea-Fly
Thread
09-07-2010 | 02:00 AM
12
ntsmith
May 2006
350
Bishop\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'s Stortford,
RE: Building the Flea-Fly
Had a long hard think about this aileron connection. I wanted, idealy, to be able to adjust either end so I could pull both ends in to increase differential or do the opposite. Plan A/ I made up two links but found that room precluded the otehrwise good idea. Plan B/ I next went the route of the plan. Simple and effective. It has just a 90 degree wire piece soldered on which just literaly sits in the servo. If the servo was to move then it could come out. Plan C/ was an adaptation of plan B which involved having the same simple wire piece soldered on but also had another 90 degree bend so it cannot escape from the servo arm. This simple answer has two draw backs that I have to live with. 1/ If I want to remove the arm I have to remove the servo and I cannot shorten or lengthen either individualy or together the lengths. The connection to the aileron 90 degree horn at the outer end will have an extender and a nylon clevise to allow adjustment. There will be incorporated a little differential for peace of mind as well.
Reply
Like
ntsmith
View Public Profile
Send a private message to ntsmith
Visit ntsmith's homepage!
Find More Posts by ntsmith
View iTrader Profile
