RCU Forums - View Single Post - Best possible Redundancy
Old 09-07-2010 | 06:26 AM
Mr Cox's Avatar
Mr Cox
Default RE: Best possible Redundancy
I don't understand the purpose of the two batteries and two switches...
The only thing I can think of is that if one switch would suddenly fail in flight (I don't know how), then you would fly on one battery rather than none, so that's a good thing.
For all other events it appears to not do much at all. Forget to charge a battery and you drain the healthy one. One battery shortcuts in the air, and you drain the healthy battery. Forget one switch and you have half the flight-time etc, etc.
I'm still all for one good NiMh battery, one good switch (protected from glow fuel) and a voltwatch that is visible from the outside of the plane.
