RCU Forums - View Single Post - RAM 500 - Startup Problems
Old 09-07-2010 | 10:10 AM
RCISFUN's Avatar
RCISFUN
My Feedback: (44)
Default RE: RAM 500 - Startup Problems
I used to have a RAM 500, it was my first Turbine
It taught me many things about Turbine operations and how to repair them
My recommendation would be to ditch the on board "co2" tank and directly connect, see
http://www.rcuniverse.com/forum/m_63...mpage_2/tm.htm
You then can regulate the gas flow manually, if the pressure drops off on the propane bottle, just shake it and it will rise back up
As others have mentioned you have to get the parameters just right, once you do she will start every time...until the weather changes[X(]
