RE: engine rebuild service?
Exactly. Would try some fuel in the carb, down the glow plug hold and through the vent nipple. I would follow up using Marvel Airtool oil.
This may well clean things up. Also you may need to take out the needle valve and pass a pipe cleaner soaked with lighter fluid or fuel through.
You can usually fix a gummy engine without a rebuild.
Tom
