ORIGINAL: DelGatoGrande
ORIGINAL: KC36330
The deeper the better and that is the middle of the tailcone.
Unfortunately that is incorrect. you only want it deep enough to vaporize the fluid, any deeper and the heat is too high and you burn the fluid giving you LESS smoke.
can you define ''Burn'' please?
as far as i know FIRE= OXYGEN + HEAT+ FUEL
please confirm my saying with this link
http://en.wikipedia.org/wiki/Fire_triangle
if one of the three is missing (in our case the oxygen that it has already used and burn in the turbine) we have no fire and the fuel can only be vaporized.
there is no such a thing as ''too much heat'' . the fluid can be burn or vaporized and since i dont see any flame that means its vaporized
my2c
+1 +1 +1 +1............ I have probably burned up more Super Dri than most. The CORRECT stick location is "SHOW CENTER" in the middle of the tailcone.
