"High Temperature" Wren Testing
CONDOE _WON,
I've got to go flying this morning, the big ones that is, but when I get back tomorrow I'll put the Reaper together and take some measurements. I know that I started with the CG at 530mm from the trailing edge as suggested. I moved a 5cell 1700 mah NiCad pack from just behind the front wing tube to just behind the canards. This was done at the field at my peak of frustration. I didn't re-check the CG. I flew and it worked great.
Regards,
John
