RCU Forums - View Single Post - adding a wing tube?
Old 09-08-2010 | 07:04 PM
rye
My Feedback: (10)
Default RE: adding a wing tube?
well ill give it a shot ,i builded a gaint ov-10 ones had a old timer show me how to make the wing ends removeable so the center section with the boom tail wouldnt have to come apart i add lite ply ribs to each side for strength and bought a wing tube and a sleeve ,now the trick here is that you need to have the holes to mount the wing sleeve if its a full rib just set up the wing to be at the dieheal or level and use a hole saw sizes for the wing sleeve as far in as you need to go,thats the way i would try it [X(] rye
