ORIGINAL: tlojak38
update. i tried taping the hinge gaps, and it came out horrible! maybe im using the wrong stuff. any suggestions?
The "hinge tape" used in electrics is not fuel proof and is for hinging, not gap sealing. Packing tape, likewise, is not fuel proof. Hatch tape s too heavy and may limit travel. I have only ever sealed one model's hinge lines and that was after flying it showed a slight flutter. It is not necessary in most models. Does make for a very "finished" look in a nice covering job.
As mentioned above: if you are going to do it then use a strip of the same material as the covering.
