RE: Servo usage?
Well I'm so glad I didn't cut into anything on the DMD, that's for sure!<div></div><div>It does work, but the mapping from thereceiverto thru the DMD crosses hairs somewhere. Put the turret rotation on left stick channel and hooked up the turret rotation motors, then wedged the servo wires into the servo plug coming from the DMD into the receiver. Nothing happens to the servo with the left stick but the turret rotation motors are turning, but if I turn left or right on the right stick, I can control the servo. Not an electronics/rc pro so I can't explain that, but that's what happened.</div><div></div><div>Anyway, as a side note....fired up the King Tiger sounds while I had the DMD out for the first time.......gotta be honest here. Other than start up and shut down....not that pleased with it.</div>
