RE: Tuning needles
Some small gas engine carbs do have a sealing ring of sorts at the base of the needle. The spring around needle places a tension on a flat washer and between that washer and carb is a special shaped sealing ring. I know....they are darn easy to loose when you take the needle all the way out. You will never notice it unless you check close for them in the first place. Capt,n
