RCU Forums - View Single Post - help with tamiya dmu
Old 09-10-2010 | 10:31 AM
BiggTony's Avatar
BiggTony
Default RE: help with tamiya dmu
The leo's programming is slightly different than my Pershing and KT. Instead of left stick-up, down then right stick-up, down,.......you immediately complete the total left stick up, down, right, left movement before moving on to the right stick.
Anyway.....
Step one: Make sure all trims and sticks are neutral. (this is your starting point)
Step two: Press the set button till the DMD shuts down and goes into program mode.
Step three: With left stick, move from neutral position, UP to DOWN back to Neutral
Step four: With left stick, move from neutral position, RIGHT to LEFT back to Neutral
Step five: With right stick, move from neutral position, UP to DOWN back to Neutral
Step six: With right stick, move from neutral position, RIGHT to LEFT back to Neutral
You should notice a quick blip of light after each completion of steps.
Once completed, you should notice a constant blip.....Re-press the set button.
(In this mode, you can also eliminate the use of trims to engage the canon, machine gun or lighting.....but you have to do some easy tweaking)<br type="_moz" />
