RCU Forums - View Single Post - LETS TRY TO POLISH SOMETHING!
Old 09-10-2010 | 02:53 PM
D.E.
Default RE: LETS TRY TO POLISH SOMETHING!
After you do the whole model with compound I switch to a soft foam pad to do the glaze. The glaze is to remove the slight haze left by the cutting agent in the compound.
It takes even less of the glaze, use the same process as the compound only work small areas at one time.
ID:	1498489   Click image for larger version
ID:	1498490   Click image for larger version
